Looking for simple example for usb-6008 and labview 7.1 to output 4V pulses tia sal
Greetings, ALL
I'm Looking for a simple example for usb-6008 and labview 7.1 to output 4V pulses tia sal
(2,805 Views)
Hi sal2,
The DAQmx Base driver installs various LabVIEW examples. You can find them by going to Start (from Windows) >> Programs >> National Instruments >> NI-DAQmx Base >> Examples >> LV7.1 >> Dynamic. An example you can use is in the Dynamics folder, called "Gen Mult Volt Updates - SW". You can change the data being output to vary between 0 and 4 instead of the current sinusoidal data to achieve a software timed pulse train.
Lesley Y.
(2,795 Views)
