Looking for software driver for HP 6655A Power Supply with Labview 5.1
Hi, trying to control an HP 6655a Power Supply but the version of Labview in the PC is the old Labview 5.1.
I don't want to upgrade it for fear that the program will no longer function. Does anyone have the driver for the HP6655a that will work with labview 5.1?
(3,082 Views)
Hi demo,
Try the drivers directly from Agilent.
Here is a couple of links:
http://we.home.agilent.com/cgi-bin/bvpub/agilent/editorial/cp_MiscEditorial.jsp?OID=536913992&NAV_ID=-536891584.536882066.03&LANGUAGE_CODE=eng&COUNTRY_CODE=ZZ
Click on> Driver: 665xA Series Instrument Drivers
Maybe this one is better... it's older...
http://we.home.agilent.com/cgi-bin/bvpub/agilent/editorial/cp_MiscEditorial.jsp?OID=536917365&NAV_ID=-536891585.536880265.03&LANGUAGE_CODE=eng&COUNTRY_CODE=ZZ
Click On > Driver: DC Power Supply Instrument Driver (1.13 MB)
You may have to import the instrument driver after you install the libraries. This is done by selecting from the pull down menu:
Tools > Instrumentation > Import CVI Instrument Driver
JLV
(3,082 Views)
Hi Demo,
You should definitely consider upgrading LabVIEW. You can probably get an "evaluation" version of LabVIEW 7.0 prior to buying it to check if your program will still work. Contact your local NI sales rep for more information.
The LabVIEW 5.1 version of this driver is attached below.
Vesna Jadric
Instrument Drivers/IVI
(3,082 Views)
