Looking for suggestion on mV graph output
Hi again and thanks for the comment,
Well, I have not tried to write down a formula for this, however, the implementation logic is simple, once the input hits the threshold then make it reset immodestly to reset values and make a static input for a few seconds, and then again produce the input and produce the same behavior.
might be this will help you to understand,
Message 11 of 19
(1,770 Views)
Hi sam,
And because the logic is simple you aren't able to produce the expected results...
Please write down the formula you want to implement in your VI, and write down the other "side conditions" in some kind of pseudocode!
Message 12 of 19
(1,767 Views)
Agreed, if it seems easy then might be already solved but as mentioned earlier the same methodology works fine. with Y-Axis (positive voltage) values but when I just tried to change the Y-Axis values to mV values or negative its stuck on static might be the negative values are so small as you mentioned but definitely, there is some implementation lake into the implementation as well.
Here is the pseudocode of the algorithm,
# Set parameters
  V_th, V_reset   = pars['-55*mV'], pars['-75*mV']
  tau_m, c_m, g_L = pars['10*ms'] , pars['0.2*nF'], pars['c_m/tau']
  V_init, E_L     = pars['-75*mV'], pars['-75*mV']
t_static = pars['10*ms']
  # Initialize voltage
  V[0] = V_init
While (True):
If V >= V_th:
V = V_reset
V = t_static
However, the other terms which are mentioned in the differential equation with required values are also mentioned above.
Hope this will help you,
Message 13 of 19
(1,764 Views)
Hi sam,
now only the formula to calculate "V" in the while loop is missing. I repeat: not that differential equation in your image, but the actual formula implemented in your VI!
(As far as I remember you forgot the "V[0]=V_init" step in your VI...)
Message 14 of 19
(1,761 Views)
Hi again,
I think you are looking for this,
(-(v-v_rest)*g_l + I(t))/c_m
best regards
Sam
Message 15 of 19
(1,757 Views)
Hi sam,
And why is there an "e^x" function in your VI?
(Please reread my messages #2 and #6 on "differences between actual implementation and expectations"...)
Message 16 of 19
(1,757 Views)
Hi again,
The ex function helps me to generate waves into the chart that's my understanding if I will remove this the chart will not produce the exact results that I am looking. This is included based on some random suggestions.
regarding comment #6, V[0] is the starting point that is already implemented into the VI where V[0] starts from the user-defined reset point values.
and regarding #2: as I mentioned many times based on the calculation with only Voltage or positive values it's right.
Could you please try to run a VI with positive or Voltage values and then just change the values of Y-Axis to mV.
Of course, I am looking for your suggestion but your questions help me a lot to understand even my own understanding on this issue but without running a VI I think that will not clear your concern as well.
Best regards
Sam
Message 17 of 19
(1,749 Views)
Hi sam,
So there is a mismatch between your expectations and the math/formulas/algorithm in your VI?
I repeat: changing the Y axis scaling will NOT change anything to the calculations done in your VI! It will only change which part of the plot will be visible...
Message 18 of 19
(1,736 Views)
Hi again,
As you are continuously referred to the implementation part which I already know and that's the reason I am not receiving the same output which is required and because of failure implementation I am looking for appropriate suggestion not just only referred that the implementation is wrong.
I will keep this question open and look for other people's suggestions that might be helpful for me and others who are following this question.
Best regards
Sam
Message 19 of 19
(1,734 Views)
