Lookup Table 1D no sign
A small spelling note: the word you want is "palettes," not "pellets."
Message 11 of 23
(1,731 Views)
Oh...thanks Nathand.
I won't repeat my mistake.Smiley Surprised
Message 12 of 23
(1,714 Views)
Hi Arihant,
Simulation VI's can only be place within control and simulation loop, found on the same palette.
CLA | CTD
NI Alliance Partner
iLV Test Solutions Ltd
Message 13 of 23
(1,704 Views)
Okay.
Then how am I supposed to use look up table function.
Actually I want to display a variable "y" for certain value of "x". there is no  amthematical relation between them. All I have is values of Ys for values of X.
Thanks.
Message 14 of 23
(1,686 Views)
No need for the special lookup table function; use "Threshhold 1D Array" and "Interpolate 1D Array" as appropriate from the Array palette. For example you can use Interpolate 1D Array as shown in the image below; the only requirement is that the X values need to be unique and sorted in ascending order.
Message 15 of 23
(1,673 Views)
Thanks Nathand. That was helpful.
One more query I have-What if, say there is a band of values of x for which we get a fixed "y".
x=(0,0.5),y=1.3
x=(0.6,1),y=2.3
and so on.
Message 16 of 23
(1,659 Views)
x=(0,0.5),y=1.3
x=(0.6,1),y=2.3
and so on.
Just enter values for the start and end of the range, so you'll need a point at (X,Y) = (0,1.3) and (0.5, 1.3). Any X value in that range will return the same Y value because the endpoints are the same and the algorithm fits a line between them.
Message 17 of 23
(1,652 Views)
If you only have two ramges, the straight line curve fit technique will work fine. If you have more than two ranges that you are comparing against, check out this recent thread. Though it doesn't sound like it from the title, they were wanting to do something very similar.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 18 of 23
(1,644 Views)
I don't understand this comment. The lookup table approach I showed will handle any number of ranges. I did mis-state one thing: the X values do not need to be unique, they just need to be sorted in ascending order. If you have three ranges, you can do this:
X     Y
0.0   1.3
0.5  1.3
0.5  2.3
1.2  2.3
1.2  4.0
2.0  4.0
Message 19 of 23
(1,638 Views)
X     Y
0.0   1.3
0.5  1.3
0.5  2.3
1.2  2.3
1.2  4.0
2.0  4.0
Hi Nathand,
As per your solution, what will be the output (y) for x=0.5 (and x=1.2 for same case)?
Will it return y=1.3 or 2.3 (and 2.3 or 4.0)?
When I tried the ranges you mentioned, result was displayed for larger "y".I dont know the reason. I changed the ranges as follows and it working:
X         Y
0.0      1.3
0.5      1.3
0.6      2.3
1.0      2.3
1.1      2.9
and so on..
Thanks.
Message 20 of 23
(1,624 Views)
