Loop Timing
(I meant that your various inner loops cannot be stopped by a  control on the front panel because they never see the value change. I did not comment on your timing logic ;))
Here's a simplified picture of the code I had in mind (sorry, I no longer have LabVIEW 6.1). The false case has the blue wire straight through but is otherwise empty.
Message Edited by altenbach on 08-09-2005 09:03 AM
Message 11 of 15
(1,321 Views)
Okay, so I like yours better.  Smiley Happy
Message 12 of 15
(1,308 Views)
I would highly recommend that you implement altenbach's solution (which is essentially the same as I suggested).  While the solution with the local variables may work it is much more complicated than necessary and breaks the natural LabVIEW data flow.  You can do all that you need to do in a nice small block diagram as altenbach has shown in his example.
Message 13 of 15
(1,305 Views)
Yeah, no kidding, I'll give it a shot and see what happens!!!  Thanks guys...
LabVIEW 2016 - Windows 7
CLAD
Message 14 of 15
(1,300 Views)
Yes, yours is basically the same, we must have replied at the same time. Another one of these race conditions... 😉
Message 15 of 15
(1,298 Views)
