Loop in a table control?//Enable write with keyboard in table control?
Hello, in my labview, I have a table control, which I fill in with a run time menu, after filling in the rows I want, the serial port reads row by row. I have a case that is called goto, its function should be to create a loop between the row where you add it and the number that you put in "Value". I can not implement it correctly, because apart from this, I can not write with the keyboard to the table control when the program is running. I hope someone can solve some doubt, thank you very much.
(2,874 Views)
Hi Aleix,
Because that "Control table" is NOT a control, but an indicator!
Please rework your VI to use NO local variables, but a shift register to hold your table data. Then switch the table to be a control…
(2,867 Views)
Ok, thanks, what a fail! Why i can't work with local variables? Isn't good?
The first doubt i explain(implement a loop with "goto"), you have any idea how to do it? Thank you so much for you help!
(2,852 Views)
Hi Aleix,
As long as your VI runs without errors it's "good"…
That being said two reasons why you should avoid them when possible:
Local variables make it easier to create race conditions.
Local variables enforce data copies in memory.
What is a "goto" (in LabVIEW context)?
Idea: Maybe you need to learn about using state machines…
(2,845 Views)
I have a case that is called goto, this function should be to create a loop between the row where you add it and the number that you put in "Number". If you open the vi, you'll see that it's a case, inside of an event structure, for the run-time menu. I don't know how to implement this, because i need to link the number in "Number" with the row with the same number. For example, if i select "goto" in run-time menu and write 1 in "Number", this action make a loop between 1 and the row you place goto, in "Value" you write the number of loops you want to do. After that, i read through serial port, that's why i want a loop, to read the table control X times sequentially, and when it finish the loop, it still reading sequentially.
Thank you.
(2,833 Views)
Hi Aleix,
So you want to implement a "FOR loop" instead of a "GOTO feature"!
A "FOR loop" needs (atleast) two parameters: the number of iterations and the position of the related "NEXT" as in text based programming like BASIC:
10 FOR x = 0 TO 9
20    do something
30 NEXT x
(2,827 Views)
