Loop sequence - parsing
Hi ,
I have designed a labview vi . i have designed it in such a way that for the first FOR loop sequence it will generate two bits .
now for the second sequence i want to negate the values obtained from the first loop sequence and pass them onto the array .
I tried doing so, but it resulted in a parsing error . I am using this with a dsk 6713. Can anyone offer suggestions to rectify this error or recommend other ways of tryng the same thing that i am looking to do . Any help appreciated .
Motorhead
Message 1 of 8
(3,996 Views)
Message 2 of 8
(3,993 Views)
Hi motorhead,
what do you mean with parsing error? Which format have your values? Can you show your code?
Mike
Message 3 of 8
(3,991 Views)
Hi motorhead,
here is an example.
Hope it helps.
Mike
Message 4 of 8
(3,990 Views)
Mike ,
  Does work ... Smiley Happy    .. God bless ya !! ..
Motorhead ...
Message 5 of 8
(3,982 Views)
Hi motohead,
and here the solution with the Feedback node. Smiley Happy
Mike
Message 6 of 8
(3,977 Views)
Hi Motorhead,
with just 2 iterations of your FOR loop it's better (faster, more readable,...) to unroll the loop. See attachment...
Message 7 of 8
(3,971 Views)
oh thanks GerdW ,
i will have to stick to Mike's solution , becasue the DSP board does not support a " build array block " .  but much appreciated .. thank you all.
Motorhead ...
Message 8 of 8
(3,964 Views)
