Loop structures
Hi
I was wondering, if there exists a while-loop in LV. Now don't think "what kind of problem has this guy - there is a while-loop" - I know there is, but compared to a textual language it's a do-while-loop (footer controled).
I want to know if a header-controled loop exists or if it may come with a future release of LV.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
Message 1 of 16
(8,011 Views)
Hi becktho,
I don't know if there's anything in the pipeline, but until then you could try a conjunction of while/case structures.
See attached VI.
Charlie Rodway | Principal Software Engineer | Certified TestStand Architect (CTA)
Computer Controlled Solutions Ltd | NI Silver Alliance Partner | GDevCon#1 Sponsor
Message 2 of 16
(8,001 Views)
Hi Charlie
I know what you mean and use it like this (still your attempt shall be honoured ;)), but I'd like to get rid of this way.
And the best thing for that was a header-controled while-loop.
Thomas
Using LV8.0
Message 3 of 16
(7,998 Views)
Hi becktho,
I have raised this topic when I've been at NI (Newbury) before. They are at least aware of the problem, but I don't know if we'll see anything soon 🙂
Message 4 of 16
(7,992 Views)
Hi Thomas,
Please make yourself heard the best way by submitting a Product Suggestion through the "feedback" link on www.ni.com/contact. That way, your suggestion will get directed to the appropriate LabVIEW developer.
Have fun!
- Philip Courtois, Thinkbot Solutions
Thinkbot Solutions
Message 5 of 16
(7,964 Views)
If you just want a while loop where the termination condition is checked before each code iteration, use something like in the attached image. I don't think we need an entirely new loop species. 🙂
Message Edited by altenbach on 05-19-2005 07:54 AM
Message 6 of 16
(7,957 Views)
Thanks for the peanut! 🙂
Strong opinions either way should probably be spelled out in a reply so we can all learn and improve our thinking. 😉
Message 7 of 16
(7,945 Views)
Hi great wizard
Yes your right - your example works. But I think it was easier if I don't have to draw the case-structure all the time. And also to have your loop available in the palette is not the right way, I think.
In addition - if you have several criteria to stop the loop, maybe it must be enlarged too much (I don't like hiding code).
Just for comparison in a textual language you don't write
do{
if(i < 5){
}while(i < 5)
Thomas
BTW - gave you a five-star rating. But as you see, the average is just 3 :(.
Message Edited by becktho on 05-19-2005 05:29 PM
Using LV8.0
Message 8 of 16
(7,939 Views)
Thanks. My main concern was that I could not come up with a simple graphical programming element design that would do what you want directly. I need to ponder a bit more....
Do you have any ideas how it could look like? How should the outputs be handled if it does not execute al all?
(e.g. similar to a FOR loop with zero iterations, which is allowed and defined).
(If the need really exists, I am sure that the wizards at NI will come up with a stunningly beautiful and intuitive new loop structure that does exactly what you want. :))
Message 9 of 16
(7,929 Views)
If, in a textual language, a standard while loop was *not* available (only a do-while) then how would it be written?
I would think it would turn out something like this:
if( condition ) {
do {
} while(condition)
IE, I guess I agree with the first posters in the group on this one 😃
Message Edited by Chaos on 05-19-2005 11:01 AM
Message 10 of 16
(7,755 Views)
