Lorentzian curve fitting
Can I do Lorentzian curve fitting with labview 4? The formula for Lorentzian fitting is y=k0+k1/((x-k2)^2+k3).
(3,830 Views)
I'm not sure if labview 4 has specific VI's for lorentzian fitting but if it does not then one suggestion would be to modify the code in these existing VI's for curvef it and saving them as another name. try this. If you do nothave any curve fit VI's let me know and I will send you the ones I have. also if you are able to use the formula node you can write your own curve fit VI. sorry I cannot be of more assistance as I am not that familiar with 4.0
Joe.
"NOTHING IS EVER EASY"
(3,830 Views)
Download a free trial of TableCurve 2D or PeakFit from
http://www.systat.com/products/TableCurve2D/
http://www.systat.com/products/PeakFit/
They will do anything you need.
- Joel
curve wrote in message news:<5065000000080000006BCA0000-1079395200000@exchange.ni.com>...
(3,830 Views)
Try PeakFit from Seasolve.com, it will perform your fitting in seconds
with no programming required.
-Joel
(3,829 Views)
