Losing data when importing excel into an array
I have been writing some code that imports data from an excel .xlsx worksheet file containing 890 columns and 150 rows.
When I set the VI to import 702 columns everything works fine.  When I try to import 703 columns I get no data in my array.  The VI continues to run without any errors just gives me no results as there is no data in the initial array.
Can anyone tell me if there is a setting somewhere Im missing or explain why this is happening as I have read that there should be no limit to the amount of columns you have as long as you have less than 2^32 elements which I am well below.  I am using a Labview 2009 and a PC with windows7 64bit and 4G RAM so there should be no problem with PC resources.
Ray.
(3,181 Views)
Hi Ray,
702 is the limit when you use just 2 chars for the column name: "A" to "ZZ" allows for 702 columns.
Probably a subVI somewhere deep in your Excel loading routine is limited for that naming scheme (or is only aware of  older Excel versions)...
(3,175 Views)
LabVIEW 2009 and MS Office 2010.  Sounds like you should updade the LabVIEW version
(3,165 Views)
RayCr,
Take a look at this snippet on the Excel board.  Should allow you to grab everything and then let you decide in LV what you need.
(3,164 Views)
I work in medical applications so using the latest versions is not always the answer due to the validation we need to perform on new software packages.
I currently work with version 8.6 to 2013 depending on the project.
To convert this project to 2013 would mean a validation process that would take several months to complete.
Easier just to fix the problem in 2009 and move on.
(3,142 Views)
Thanks guys I have figured out a workaround.
If I save the excel file as tab delimited rather than .xlsx and use that everything works ok.
Thanks for your input.
(3,141 Views)
