04-10-2006 08:13 AM
Hello everyone.
I’m developing an application for TPC-2006 with LV8 and PDA 8 module. I have deployed the application into the device and works fine, however after a turn off the application is deleted from the device. Anyone knows how can I store the application in a non-volatile memory zone? The TPC-2006 has no memory card.
04-11-2006 06:30 AM
The TPC 2006 has, according to its data sheet, 64 MB SDRAM, 64 MB flash memory onboard, and a CompactFlash memory expansion slot. To me, means that it should behave like other PDAs. I thought I had a similar problem during the first hour of utilisation of my iPaq... until I discovered that the files where saved in the Document folder, while I was searching the Application folder... ;).
This being said, the TPC 2006 is a National Instrument product and you should obtain a better help from NI engineers !
04-11-2006 09:19 AM
Thanks for you help.
The location where we can put files without lost them is in \harddisk.
