Lsm303 read data
hi, i'm Vincenzo, an electronic engineering. I'm realizing a work about LSM303, accelerometer and magnetometer, I've to work with Arduino and Labview: can someone help me with the implementation of the .vi to read acceleration data and magnetic field data into two graphs?
Thank you for the answers.
Regards
(3,846 Views)
Hi Vincenzo,
I can send you a typical example to read an analog input from Arduino with Labview through "NI Labview Interface for Arduino Toolkit". Starting from this example you'll can modify it for your purpose. Have a good time!
Enzo
AE Senior
(3,819 Views)
Thank you so much. I'll try to learn how to use these two powerful instruments, Arduino and Labview.
I wish I can ask something else if I'll need it!
Best regards.
(3,810 Views)
Hi! Working and studying various documentation about this sensor, I've found a sketch for Arduino. I've a question: why getLSM303_accel and getLSM303_mag functions are realized in two different ways? I would understant to be able to interpretate this code. These are the function:
void getLSM303_mag(int * rawValues)
  Wire.beginTransmission(LSM303_MAG);
  Wire.write(OUT_X_H_M);
  Wire.endTransmission();
  Wire.requestFrom(LSM303_MAG, 6);
  for (int i=0; i<3; i++)
    rawValues[i] = (Wire.read() << 8 ) | Wire.read();
void getLSM303_accel(int * rawValues)
  rawValues[Z] = ((int)LSM303_read(OUT_X_L_A) << 8 ) | (LSM303_read(OUT_X_H_A));
  rawValues[X] = ((int)LSM303_read(OUT_Y_L_A) << 8 ) | (LSM303_read(OUT_Y_H_A));
  rawValues[Y] = ((int)LSM303_read(OUT_Z_L_A) << 8 ) | (LSM303_read(OUT_Z_H_A));
I thought to realize in egual ways these void.
Thanks, regards
(3,685 Views)
How is your question related to LabVIEW? Shouldn't you be posting to an Arduino forum?
(3,677 Views)
