Luminary Micro LM3S8962 display data on graph
Hi all,
I need help on how to use ARM Microcontollers LM3s8962 to display a graph on the LCD screen. Using Labview 8.6 and LM3s8962
Hong Shan
(3,816 Views)
We will need a lot more information! I'm pretty sure that LabVIEW doesn't run on ARM microcontrollers (yet) so I'm guessing that you need to pass info to the micro-controller. What does the micro-controller expect, communications wise? Did you display the graph shown in the picture? How did you do that?
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(3,797 Views)
The graph on the picture is I find a online workshop that uses ARM micro-controller with Labview (the link just below here). The topic under exercise 4: Navigation Buttons and GUI. I would like to find out the GUI to Sinus on graph.
http://www.redacom.ch/software/arm_keil/docs_infopage/documents/other_arm_related/arm_cortex_labview...
I able to display some text and a pixel but I want it to display a graph with analog input. The below picture is what I am using for my project. Photo Dec 20, 12 33 20.jpgPhoto Dec 20, 12 31 41.jpg
(3,768 Views)
Sadly, that is being done with the LabVIEW embedded module, an expensive addon. 😞 I'm not sure, but at the link there may be a 60 day trial download.
Putnam
LabVIEW Champion
(3,747 Views)
