M Audio Delta 1010L not working with LabVIEW 8.5
I have just upgraded to 8.5 and now I cannot get the Conituous Sound Input.vi Example  to work with the M Audio Delta 1010L sound card.  I always receive a timeout error message, However; when I change the Device to my mother board sound card it works fine. I just tried the latest drivers for the Delta 1010L and no luck...  Any ideas?
(3,382 Views)
I do not have an M Audio Delta 1010L card, but I do recall the Delta 44 and Delta 66 show up with multiple device IDs (they look like multiple sound cards to Windows/LabVIEW).  Do you see other device IDs?  There could be a conflict with the multiple sound cards on your PC, what happens if you disable the built-in sound card from your PC's BIOS menu?
(3,371 Views)
Don't know if this will help and it HAS been a long time since the original posts but this may help someone else anyway.  I've been working with the Delta 1010 for playback and did have some timing/timeout issues with it.  Ended up with the attached LV8.2.1 code that works fine.  Unfortunately I don't believe it's possible to fully utilize ALL of the capabilities of the M-Audio Delta units using the built-in LabVIEW audio functions and VIs.  To do so would require the use of the Steinberg Audio Streaming Input Output (ASIO) API and I don't believe that you can get there from LabVIEW.  Take a look at the Steinberg ASIO SDK (http://www.steinberg.net/en/home.html) and at the PortAudio web site at http://www.portaudio.com/ to learn more about ASIO.
(3,000 Views)
