MAKE AN IMAGE USING A FUNCTION
HI genius....
i want to make an image using the function 1/cos(RotAngle).The image will look like i have attached below.
faithfully.
akhil...
IamAKR
(2,921 Views)
Hi Ragil,
the attached image just shows black/white stripes.
How is this related to "making the image using 1/cos(Angle)"???
(2,904 Views)
Are you saying you want to rotate the image using a rotation matrix?
(2,897 Views)
ya....
i want rotate this image using that equation.!!
IamAKR
(2,884 Views)
Hi Ragil,
why don't you say so in the first place…
Did you search the forum for "rotate an image"?
(2,871 Views)
Convert your image to a matrix. Construct a rotation matrix of the same dimensions as your image (assuming your image is square). Insert 1/cos(theta) as your rotation angle. Multiply them together and your done.
(2,857 Views)
