MAKING INSTALLER GENERATES ERROR CANNOT FOUND ADSAPI32.DLL
I'm trying to make an installer for my application but when I press button "build" this generates an error: Cannot found ADSAPI32.DLL, why?
Thanks in advance,
ToNi.
(5,452 Views)
I know what is the problem but I don't know how to solve it.
Anybody can help me please?
First of all, I make my installer for my application, and then when I execute it from (c:\archivos de programa\LabSBRs\LabSBRs.exe (where LabSBRs.exe is the executable I run) I receive the error that appears in the file error.jpg I attach here.
This error is propagated because in a place of my top-level vi, (see file blockdiagam.jpg I attach here) I want to create a file inside the directory where LabSBRs.exe application created is executed, but I don't know why but LV takes the incorrect path, see the indicator appended path 4 in the file error.jgp. For LV in run time the path is: C:\Archivos de programa\LabSBRs\LabSBRs.exe\language.ini (language.ini is the file I want to create) but I want the path to be the following: C:\Archivos de programa\LabSBRs\language.ini
How can I solve this?
Thanks in advance,
ToNi.
(5,448 Views)
Toni,
take a look into this and you will have the reason:
http://digital.ni.com/public.nsf/websearch/FD7DE8BC8FFC256C862565F4006BE363?OpenDocument
As you will see, the functionality of Current VI's path is different from LabVIEW development enviroment or from the executable.
You also have a workaround in the same KBs.
crisR
(5,431 Views)
