MATHSCRIPT in LabView 7.1
tst is right.
Using the Ramp function is much easier.  Same issues with the use of doubles..
I was too focused on reproducing the Matlab code that I lost sight of the basic function that it represented.
The Ramp function in LabVIEW is similar to:
linspace(start, stop, points)
There is an interesting variation of the results with each method.
Message 11 of 16
(1,702 Views)
Accepted by topic author winter888
Hi Ray,
Thanks a lot for your help. I have solve it. I got 10 points for 't1' and 11 points for 't' . Its exactly as the mathscript.
thanks all of you.
Message 12 of 16
(1,685 Views)
Hi Ray,
Ramp is a great function. Thanks a lot.
Message 13 of 16
(1,680 Views)
Then you should mark Ray's message as the solution to your question rather than your own thank you message.  First you will have to go to the options menu to the upper right of your message to unmark it as the solution.
Message 14 of 16
(1,676 Views)
Hi Ravens,
Sorry for that. I didn't mean to insult Ray. I appriciate the help. But there is a bit difference between Ray's and mine code. I changed a bit, and it is the exactly what mathscripts 't' and 't1' dose. Please see my attached file.
Thanks.
Message 15 of 16
(1,672 Views)
Really?  What you have looks pretty much like what Ray gave you in message #9.  So he gave you 99% of the answer, and your one tweak of the way to derive the final array is the solution?
Message 16 of 16
(1,663 Views)
