MATLAB Node without a MATLAB Licence?
Hey,
I've seen that LabVIEW demand the installation of MATLAB when executing a MATLAB Node. We have only one licence of MATLAB that's not installed on the LabVIEW PC. Is there a MATLAB runtime engine available to execute MATLAB Nodes without the completely installation of MATLAB (e.g. like LabVIEW runtime engine)?
Thank you for all reply
C. Dietz
digades GmbH
Christian
Test Engineering
digades GmbH
www.digades.com
(3,164 Views)
You need to have a licensed copy of The MathWorks, Inc. MATLAB® software version 6.5 or later installed in order to use the MATLAB script node.  Unfortunately, I do not know of anything like a MATLAB runtime engine.  However, introduced in LabVIEW 8.0, the MathScript node may be able to natively execute your particular scripts.  It uses a syntax that is generally compatible with the MATLAB software.  LabVIEW 8.2 added support for the MathScript node in the application builder so you can deploy your applications to PCs that don't have a version of LabVIEW installed.
MATLAB® is a registered trademark of The MathWorks, Inc.
Grant M.
Staff Software Engineer | LabVIEW Math & Signal Processing | National Instruments
(3,136 Views)
