MATLAB Script
Hello i am doing a project with Labview 7.0 express. When i tried to add a Matlab script i could not find the browse future, i need that future because when the program runs i need to change the sourse of the Matlab file and the Matlab file it self without stopping it. I need your help to find that future .
Thank you.
(3,348 Views)
Can you give us the syntax for the command you are trying to use?
Chris J
(3,322 Views)
Yes ,i will but unfortunately i can give you the script only at Sunday
(3,311 Views)
Here is the syntax that i use :
clear
all;
close
all;
x=[0:0.1:10];
y=sin(x);
plot(x,y)
(3,292 Views)
Running that code seems to work just fine in my script node. Are you having a problem with this code?
Chris J
(3,261 Views)
