MATLAB session timed out when using MATLAB script node
Hello!
I am using a MATLAB script node in my LV2017 application.  (Which I compile to an EXE).  It works great!
However, one very large annoyance that I'm running into is that after a certain period of time of inactivity, the MATLAB command window will time out as shown in the screenshot:
After this times out, there is no mechanism (known to me) to start a new session.  This forces me to restart the LabVIEW EXE.  (ouch)
Does anyone have any suggestions for me here?  I'll take either:
  • a mechanism to prevent timeout (set inactivity timer to infinity)
  • a mechanism to launch new MATLAB session when needed without restarting the EXE
Thanks!
(4,786 Views)
An idea just popped into my head --> I can write a LabVIEW daemon to make small (basically no-op) call to a MATLAB script node every 60 seconds to prevent the session from timing out.
This is hokey, but it will atleast serve my purpose here until somebody potentially offers a better solution.
Thanks!
(4,772 Views)
Accepted by topic author brentjustice
Whelp, I'm dumb.
Apparently, any call to the MATLAB script node will open up a new session if the previous session timed out.
Nothing to see here folks, move along
(4,759 Views)
