MAX Can't Delete Network Device
I have about 5 devices under network device, when I right-click on each instrument the "delete" function was grayed out.  Is there a way I can do a force delete?  I've tried checking the registry but couldn't come up with anything.  Anyone knows if there is a text file, registry key, xml file, etc...where MAX stored previous device settings that I can modify?
(3,514 Views)
Check in this folder:
C:\Program Files\National Instruments\MAX\INI
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(3,496 Views)
