MAX Configuration Server Corrupt
@Worle wrote:
Just to re-clarify my question. I am after the best way of making code resilient to MAX database corruption issues. A lot of our code goes to customers who aren't knowledgeable with NI software/hardware and as far as they are concerned just want a magic black box. Everyones comments has confirmed that I am thinking along the right lines so I am going to have an experiment today.
@Mancho00 wrote:
We have ~20 computers using DAQ devices, and I get one with a MAX database corruption every 3-6 months.  It's definitely not due to software installation/update, either.  There is a reason NI put a menu item in MAX to fix it...
Mancho, I am guessing you are referring to the 'Reset Configuration Database' button?
@JÞB wrote:
@BS,  look into my older posts about NI Device Manager.  It is possible to automatically detect a new device and then associate it with everything DAQmx-ish with a simple executable and some adroit HKEY NInja like moves in the same installer.    <Don't do this at home!  We are professionals >
What posts are you refering to here JpB? I can't find them on your profile.
Devmon may be the best search term.  The use of it is  fragile! I do not recommend it!  <I think that it has been useful twice in twenty years >
How do you manage the Client that thinks "Well... this is just LabVIEW,  not SOFTWARE " ? ???? Should not be as "amusing " of a topic as I believe it could be.
Message 11 of 11
(457 Views)
