MAX DB corruption/instability
I'm having problems with MAX DBs corrupting on a regular basis. The station do suffer some power outs, but shouldn't the DB be mostly a Read only access? Any suggestions on how to improve behaviour?
Qestit Systems
Certified-LabVIEW-Developer
(1,163 Views)
All I know is that if these two services don't start, the database will act like it's corrupt until you start them and restart your computer:
Sometimes it's the antivirus app that gets in the way of loading them, and only intermittently so.  Some people have had success setting them to automatic, delayed.  I have no idea why this works.
Bill
CLD
(Mid-Level minion.)
(1,157 Views)
It's worth a shot, i'll see if they're shut down.
Qestit Systems
(1,119 Views)
I have faced similar problems with MAX, with 2017 version. Specifically, with VISA driver. It was happening even if the required services are running properly. Had to uninstall all the (LabVIEW/Max/Visa) software's and reinstall with compatible max/ visa version to solve the issue.
bp
(1,087 Views)
