MAX Lockup at Refresh and Labview 6.0.2 Lockup when opening some of the SubVI
I have Labview6.0.2 standard installation on a PC with Windows 2000. After mass compiling some Test Executive 5.1.1 and Labview 5.1.1 VI libraries. Some of the SubVIs that were created in Labview6.0.2 originally opened properly no longer launched when trying to open from Labview6.0.2, and opening these VIs also locked up Labview. MAX also locked up at Refreshing. No error message showed when MAX and Labview Locked up. Any comments on what might be causing this is appreciated. Thanks a lot.
(2,681 Views)
Hello Valen Li,
Thank you for contacting National Instruments.
Try reinstalling LabVIEW. The problems you are experiencing may be associated with LabVIEW and not with the VIs themselves. Also, before compiling, try opening your LabVIEW 5.1.1 VIs in LabVIEW 6.0.2 and resaving them. The following link will take you to an article about mass compiling and exactly what it does. It may help shed some light on the cause of your problem.
http://digital.ni.com/public.nsf/websearch/654877E62A97B72986256C95006F9B24?OpenDocument
If you have further questions or problems, let me know.
Matthew C
(2,681 Views)
