MAX & 230400 Baud Rate Setting
@aderogba wrote:
A lower baud rate works in LabVIEW or when you use TeraTerm (or both)?
  • Lower baud rate ( less than 128000 & 230400 ) works fine in MAX and Tera Term.
Also, is this a "real" COM port or a USB-to-serial adapter?
  • USB-to-serial adapter
USB-to-serial adapters with a Prolific chipset have been known to cause issues with high speed communications (as well as a host of other issues) + LabVIEW.  I'm not sure if this applies to MAX as well.  No one really knows why this is so.
I know I'm talking about "workaround" now, and not "fix", but Is there a particular reason you cannot use a lower baud rate?
Bill
CLD
(Mid-Level minion.)
Message 11 of 13
(1,186 Views)
Thanks billko. The application will not work properly at lower baud rate that is the reason for the emphasis at high rate. Based on your suggestions, I am doing additional testing, I will post my update soon.
Message 12 of 13
(1,162 Views)
I wish I had an answer for you instead of more questions.  😞
Bill
CLD
(Mid-Level minion.)
Message 13 of 13
(1,154 Views)
