MAX and NiDAQ compatibility
We have a non plug and play DAQ bord that is only supported by NiDaq 6.1 and earlier. We are using LabView 4.1 and Win95. Presently we have MAX (Measurement and Automation Explorer) 2.0.3.6 loaded with NiDAQ 6,8. Is MAX compatible with earlier versions of NiDaq? What would be involved in rolling back from NiDaq 6.8 to Nidaq 6.1 (All of our hardware is supported with NiDaq 6.1)?
Conrad
(3,262 Views)
MAX is not compatible with earlier versions of NI-DAQ. You can, however, go back to an earlier version of DAQ. Just uninstall NI-DAQ, and install the earlier version. You will need to use the NI-DAQ Configuration Utility instead of MAX to configure your DAQ hardware.
Joe
(3,251 Views)
If a go back to NiDaq 6.1, will I have to change my channel descriptions in LabView to be based on the Dev # and Channel #, instead of using the names that I assigned in the MAX utility? Is there an earlier program that allowed this name aliasing capability?
(3,245 Views)
Yes, this program was called the NI-DAQ Channel Wizard.
(3,241 Views)
I am trying to remove NiDaq 6.8 and MAX before I install NiDaq 6.1 for my legacy boards. When I try to add/remove from the control panel, I am not given the option to remove NiDaq. It only allows me to deselect support for LV 5.1, 6.1, Visual Basic, etc. Is there a written procedure somewhere on the best way to roll back the Nidaq drivers?
(3,223 Views)
Give me your email address please and I would be able to give you a software that will help you out remove these programs.
LA
(3,208 Views)
Conrad.Seymour@fsi-intl.com
Thanx
(3,197 Views)
