10-16-2007 12:38 AM
I'm working with LV6.i. I recently bought a new PCI-6534 card. This card isn't compatible with Ni Daq6.8 installed with LV6.i, so I changed it by Ni Daq7.0. No problems during installation (in comparison with early attemptions to install Ni Daq 6.9.3 with as result: errors in MAX, no daq icones in LV). No problems in LV; daq icones are still available. But when I open MAX, I get an error involving a read instruction to memory: "LabWindows/CVI: NiMax.exe - error".
I had installed LabWindows on my pc a couple of weeks ago, but I uninstalled it later on.
How can I resolve this problem?
kind regards,
Kevin Van de Gaer
10-16-2007
08:50 AM
- last edited on
06-24-2025
05:25 PM
by
Content Cleaner
I think 7.0 is actually DAQmx and the message you are seeing seems to confirm that. I'm not sure why MAX would have an error but you cannot use DAQmx with LabVIEW 6. You need the driver that is now called Traditional NI-DAQ. The latest version is 7.4.4
