MAX unexpected error
Hi there,
I have the following installed onto my machine (Windows 7 32-bit, 4GB RAM)
1) LabVIEW 2010 SP1
2) MAX 5.0
3) NI-DAQmx 9.2.3
I have also a PCIe-6361 installed.
When I tried to open the Test Panel in MAX for the PCIe-6361, the Test Panel does not appear. Then, when I right-click the PCIe-6361 >> and click Properties, MAX threw an error saying that it has encountered an "unknown" error. MAX then shuts down by itself.
The error logs are attached here.
I have tried to repair MAX and DAQmx, but the result is still the same. Does anyone has any idea what could be the cause?
Thanks and Best regards,
Victor
(2,903 Views)
VLg,
Have you tried one of these?
http://digital.ni.com/public.nsf/allkb/2C7480E856987FFF862573AE005AB0D9
https://decibel.ni.com/content/docs/DOC-12805
aCe
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
(2,894 Views)
I have an issue similar to the one mentioned above.
I am also running a machine on Windows 7 - 32 bit with both Labview 2009 and 2011 installed on it.
I'm opening MAX and in Data Neighborhood i'm trying to Create New NI-DAQmx Task and Global Virtual Channels.  When I click on one or the other to try and set up I get the error message shown in the attachment.  I am using MAX version 5.0.  Any advice of what I may be missing or doing wrong?
(2,855 Views)
