MAX will not display any installed modules mounted to cRIO-9074 chassis WinXP SP3 LV2010 developer
MAX will not display any installed modules mounted to cRIO-9074 chassis WinXP SP3 LV2010 Developer Suite.
I can see the backplane in MAX and Project explorer but none of the modules show up for configuration in the drop down lists.  The LV was just installed on the PC with RT/FPGA/Sound and Vibration. I have Admin and am accessing through a PCMCIA Ethernet card. I have to disable normal wireless Ethernet just to see the cRIO unit at all.
(2,661 Views)
Well, you actually won't be able to see the C-series modules for a cRIO in MAX.  Take a look at this KnowledgeBase article for a little more information.
As far as not being able to see them in the Project explorer, are you trying to run in FPGA or Scan Interface?  If you're using the FPGA Interface, you'll have to make sure to expand the FPGA Target tree in the Project explorer to see these modules.
Austin S.
Academic Field Engineer
(2,645 Views)
