MAX4 forgets view settings
I have another problem with MAX4. Smiley Mad
Currently every time after rebooting my computer, MAX4 complains that it can't load my views and will use default settings for this. So it forgets all the colours I chose, the renaming of traces, the chosen timeframe, and the scaling settings. Smiley Sad At least it still remembers the traces.
Really weird is, that this just happens after booting! If I just close MAX4 and start it again, all loads fine...
So long,
    Carsten
(2,747 Views)
Hello Carsten,
I would like to try to reproduce this, but I need some more information about what exactly you are doing.
Are you working with LabVIEW DSC or with the VI logger, and which versions of the software are you using?
What exactly is the error message you get when starting the MAX after booting your computer?
regards
Ingo Schumacher
Systems Engineering Manager CEERNational Instruments Germany
(2,738 Views)
