MCListbox property node not working during run-time
Hi I have problem with MCListbox's property node. I wanted to fill the column  with names and items in the table.
At first the program is running smoothly under development time with no errors.
However when I ran it during the run-time the table cannot be filled and error is produced. The error says that "Config Data Registry.vi [get section]: invalid object 0".
I am not sure what the error means I have to find the bug  under the run time as it works fine  under  the development time. I found the errors from property node of MCListbox after  the names and items  are attempted to be filled in the table. I am not sure why there are errors  unlike  in the development time. See the attached below
Please advise Thanks
Clement
(3,331 Views)
Accepted by topic author astroboy
Are you reading the data from configuration file? How do you get the path to it? You know that there is difference (http://digital.ni.com/public.nsf/allkb/FD7DE8BC8FFC256C862565F4006BE363) between the path at runtime and development environment? What version of LV are you using? There were some recent changes. http://forums.ni.com/ni/board/message?board.id=170&message.id=473427&jump=true
Message Edited by ceties on 02-08-2010 05:38 AM
Message Edited by ceties on 02-08-2010 05:40 AM
LV 2011, Win7
(3,324 Views)
Hi Ceties, Thanks.
Just the misplaced the path wire though I have used my function that determines the path in case of  kind of the application being run.
All are solved
 Clement
(3,293 Views)
