MCP2210 dll in labview
I am trying to read serial number of MCP2210 using dll and .net.
Using dll: The LabVIEW crashes.
Using .net: Handle and SerialStr are inputs in form of pointers which I am not sure of what to pass.
I need help with reading the serial number.
Thanks in advance!
VR
(1,377 Views)
Thanks in advance!
VR
Where are your VIs showing the work that you have done?
(1,336 Views)
And mention where you got the DLL from and what bitness you are trying to use this for. If you try to use 64-bit LabVIEW your main problem likely is that all the VIs out there were developed for 32-bit LabVIEW and did not care about 64-bit compatibility (or were created in a version before LabVIEW 2009 which was the first to be available as 64-bit version).
Rolf Kalbermatter  My Blog
(1,331 Views)
