MD5 File 2020 Replacement?
Okay so in 2018 I used the MD5 Checksum File.  And in 2020 it isn't on the palette and the description states.
"This VI is deprecated. Use the File Checksum VI."
Okay so I find the File Checksum VI, and there isn't an MD5 option.  Was this function deprecated with no direct replacement?  Yes I realize I can still just use the function but I feel like NI should have had an MD5 option in the new File Checksum function.
Message 1 of 12
(6,820 Views)
I was told that MD5 is contraindicated now due to security concerns, and that the new checksum VIs specifically exclude it for this reason.
Message 2 of 12
(6,791 Views)
Okay thanks for the response.  It is just add to me that it was flagged as deprecated but doesn't have a replacement.  I mean I get the motivation, but if I do need to take and actual MD5 of a file, then I guess I'll be using this older function.
Message 3 of 12
(6,782 Views)
Yeah, I guess it's just semantics. A replacement is provided, one that doesn't have the security flaws inherent in the original implementation.
Message 4 of 12
(6,779 Views)
Put another way, NI doesn't think you should use MD5 anymore, so we've provided this better way. If you still want to use MD5, we left the old VI around.
Message 5 of 12
(6,776 Views)
My co-worker (who is new to LabVIEW) just ID'd this problem to me, literally yesterday (new user = latest version, I'm still using 2019SP1).
I came away with the same conclusion - they REALLY don't want anyone to use MD5 for the vulnerability - though of course it's still there in the library for backwards compatibility.  Complete with red X and deprecation in the description.
Dave
David Boyd
Sr. Test Engineer
Abbott Labs
(lapsed) Certified LabVIEW Developer
Message 6 of 12
(6,721 Views)
From a security point of view MD5 is indeed outdated and insecure, but as a simple hash for fingerprinting a string or file for instance it's not really a big problem to use. I'm not really convinced that it would need such stringent measures.
A message on the front panel and a red exclamation mark in the icon would have been enough in my opinion 😁
Rolf Kalbermatter  My Blog
Message 7 of 12
(6,702 Views)
Yes, using MD5 to validate simple copy and paste of test data from a local computer to a server is still considerd a safe and valid way to use the checksum.
Perhaps less safe is to continue to use it for input files that our own engineers create, however going back and changing that for already released test files is not something thats going to happen.
A more nuanced solution would have been appriciated!
Message 8 of 12
(5,840 Views)
Working in LV2020 and was looking for the the MD5 checksum to do this specifically.  I'm reading it's technically available, but do you have to have an older version of LabVIEW?  Cuz I don't see it anywhere.
Message 9 of 12
(4,410 Views)
It's still present in my LabVIEw 2020 installation under vi.lib\Utility\MD5Checksum.llb\MD5Checksum File.vi and vi.lib\Utility\MD5Checksum.llb\MD5Checksum String.vi. It's even in 2024 present under the same name but the LLB has been turned into a directory with the same name.
With a big red cross through the icon!
Message 10 of 12
(4,406 Views)
