MIB520
Hello everyone i'm trying to connect a crossbow kit with gateway MIB520  to Labview so how do i represent the MIB520 in Labview so that it recognizes the Hardware device ?
(3,437 Views)
Did you try googling mib520? The first link was this [broken link removed].
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,416 Views)
yes indeed and i downloaded the packages and so but the examples creat the stream i want to represent it by VISA and i'm having a problem doing so
(3,394 Views)
What do you mean you want to represent it by VISA? What are the problems you are having?
Mike...
LabVIEW Champion
(3,381 Views)
like when I tried to run this example example labview
when the MIB520 was connected  it ended with errors i wanted to see how this code acted to make some changes ....
and according to the link you kindly shared it was supposed to display the data ..... also the other example attached although i changed the sensor board to MTS400 as the one with us
(3,370 Views)
finally i was able to represent the MIB520 in the program
using this this 🙂 but after my computer recognizes it still can't read the data correctly !!
(3,344 Views)
