MINUSING 2 GRAPHS
johnsold + 1
I have been guilty of it many times in the past, and I am sure I will do it again, so don't beat yourself up to much about it!!
Dom
Message 21 of 40
(974 Views)
Hi all. I'm back Smiley Happy
I've studied my example, and corrected my mistakes. Finally I get Sum2 2D array.
Now I can clearly explain what I need to do for finishing my work.
I want to get graph of Sum2 regardless of Xm.(Finally I must receive 5 plots in one window: every column of sum2 regardless of Xm).
Can you help me with this?
Thank you so much in advance.
Message 22 of 40
(945 Views)
Here is my program.
Message 23 of 40
(944 Views)
Hey Moony,
I hate to say this but it doesn't really clear things up for me.
Build up a flow chart of how you expect your program to run.
It's hard, but it is very very very very good practice and will help you and others with debugging / program building.
Dom
Message 24 of 40
(937 Views)
In this case, please answer my last question.
Simply just say how can I use columns of 2D array. In other words, how can I split every column of the 2D array to the 1D array?
Message 25 of 40
(933 Views)
Index Array will let you get one column at a time.  Just wire to the column index input.  See the Help for more details.
Lynn
Message 26 of 40
(929 Views)
Thank you for your help and patience.
Message 27 of 40
(919 Views)
How are you getting on?
I have had another look at your latest program, getting the five graphs onto on chart is easy enough, I have done it in the attached program, but I am still not sure what you meant by the preceeding sentance:
"I want to get graph of Sum2 regardless of Xm"
Dom
Message 28 of 40
(906 Views)
It would help if I attached the vi!!!
Message 29 of 40
(905 Views)
Hi, Dominic.
Thank you so much for your post. I couldn't open your file, because my Labview version is 8.5.
Please, send me your file by saving for my version.
Thank you in advance.
Message 30 of 40
(900 Views)
