MIT Not loading the Dll
I wanted to interface compiled simulink model into Labview. I am using MIT toolkit 2013 f2 to run the model.
The load Model function throws error while running, please refer the attached screenshot.
The same model is verified in Veristand 2013 ,It is working fine. What is ideal solution to fix?.
Any special consideration need to taken during compilation of simulink model?. Ideally MIT should work if its working in veristand
Thanks in advance for your help.
Regards
Rigil
Message 1 of 1
(2,663 Views)
