MKS PR4000 CONTROLLER driver for labview 8.6
Thank's Blokk for your instant response. I've done the following and it seems that is working fine.
Message 71 of 80
(1,979 Views)
You could use a while loop instead of the FOR loop. Also, stop the loop if there is error, or if you click on a stop button (use a logical OR function). After the loop, you only need to use a single "stop" vi (or release, cannot remember the name of the subVI to release the com port), do not use 4 of them 🙂
Message 72 of 80
(1,973 Views)
Thanks for the advice. I don't think I need to put a stop button because the code in my photo is essentially a sub-VI and it stops when i click the stop button from the VI.
About the multiple ends out of the loop; I have to keep one end VI and connect it with one component?
Message 73 of 80
(1,961 Views)
Using the red abort button to stop a running vi is a brute action and should be never used for normal applications. I do not understand your explanation: if you use this vi as a top level vi, you should use it with proper stop button. If this is a subVI called from a main vi, I guess you run it for a predefined times using the for loop? This part is not clear. About the "stop" pr4000 subVI from the driver: you can connect it to an error output after the loop. But you do not have proper error handling either, this should be fixed, as I wrote before. The four subVI in your loop as you use it, does not make too much sense either: you try to read out four values in parallel. You do not understand how a FGV works: even if you placed these subVIs parallel, at once only one of them can be executed (non itinerant execution). So just place them in series, using a single error wire...
Message 74 of 80
(1,958 Views)
Yes, it's a subVI and it runs for predefined iterations. Thank's.
Message 75 of 80
(1,952 Views)
This program is very useful to me, I hope you can send me a copy, thanks
Message 76 of 80
(1,909 Views)
You should properly specify what you are asking for, and from who? We cannot read your mind 😉
Message 77 of 80
(1,903 Views)
I'm interested.
Can you send me a zip?
My email is caterino.stringola@enea.it.
Thank's
Message 78 of 80
(1,818 Views)
What specifically are you asking for and from who? Might be easier to get the zip if it's a little bit more specific.
Message 79 of 80
(1,799 Views)
Can you share the labview vi with me as well?
Message 80 of 80
(1,322 Views)
