MMI in a 'while' loop?
Hello all,
With Labview, i want to launch a windows to request login and password from
a file.
I already done this as a vi, but if i want it to work, i must use a while
loop waiting for user entry. This method take almost 100% CPU.
Is there a way to wait passively for user entry? As a button callback in
labWindows CVI?
jm
(2,538 Views)
Hi
The "problem" is that LV executes the while loop as fast it can (100% CPU usage). The workaround is to place a "wait until next ms multiple" (Time & Dialog pallete) ito the while loop and set a value of about 100ms. This value is enough for user interaction.
If you have LV 6.1, than you can use the "event structure" (no polling).
Luca
Luca
(2,538 Views)
