MOD-Bus drivers
MOD-Bus is a simple protocol for serial communication, several controllers
(e.g. JUMO) work with this protocol.
I have to write a program for a teststand with some of those controllers.
Has anyone written some LV drivers which handle the MOD-Bus protocol (handle
address, checksum, error control,... ). Maybe there is even someonen who
hase written drivers for JUMO-controlers (dTron)?!
Max
-> max.weiss@web.de / max.weiss@gmx.de <-
-> Max Weiß * Eulenweg 2 * 76356 Weingarten * Germany <-
-> Fax/Voicebox: 01212-5-105-70-879 * Tel: +49 162 9114507 <-
-> ICQ: 123429315 * DB 8 MWE <-
(4,739 Views)
Yes there are several versions of Modbus drivers out there for LabVIEW. If you search the list archives for you should find several messages about it. Try the following link to get you started:
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RPAGEID=135&HOID=506500000008000000A1350000&UCATEGORY_0=_49_%24_6_&UCATEGORY_S=0
I hope this helps
Brian
(4,738 Views)
HI
PLESE HELP TO ME I AM  STARTED WITH MODBUS TO MY DEVICE . I KNOW  MODBUS FUNCTION CODES  BUT HOW T0O USE IT I DID NOT UNDERSTAND PLESE HELP ME
(4,354 Views)
You can find a modbus library on NI's website here.   If you serach the forums some more, you will find some code that others have written as well.
(4,348 Views)
