MODBUS TCP with Modbus Library
Is it possible to communicate with a device MODBUS TCP with the modbus libraries for labview? I am using it succesfully with MODBUS RTU serial, but dont see how to use it with ethernet.
ANy ideas???
(4,835 Views)
Any tutorials for Modbus TCP communication???
(4,826 Views)
Hi Jaime!
The library that you can download for Modbus communication, includes examples for TCP/IP communication. The examples include instructions of use and just require a Master and a Slave to work. Im including the link to where you can download the library and to some information that can be useful to you:
Modbus Library
http://zone.ni.com/devzone/cda/epd/p/id/4756
Helpful Links
http://digital.ni.com/public.nsf/allkb/C3D8E30CF992B8CD86256FC8001CA598?OpenDocument
http://forums.ni.com/ni/board/message?board.id=170&message.id=325726&requireLogin=False
The VI's that install with the library are called:
MB Ethernet Example Master.vi
MB Ethernet Example Slave.vi
I'm ataching a picture of the front panel of both.
Hope this helps!
Have a great day! 🙂
(4,784 Views)
