MODBUS library error 6011
Hi There,
I am trying to talk to a MODBUS device via ethernet using a GE Multinet - ethernet to serial converter. I can establish the TCP connection but when I try to "read holding registers" using "MB ethernet Master query read holding registers (poly).vi" I get an error code of 6011, exception code 11.
I can read and write to and from the MODBUS device using other software so I know the hardware is configured and connected correctly.
Does anyone have any suggestions as to what may be going wrong here?
Sean.
(4,336 Views)
I'd suggest to use wireshark to monitor what's being sent and received to/from the MODBUS device.
I think the problem is due to the fact the you are using the Ethernet vi but the interface on the device is serial.
In the past I had to slightly modify the vi in order to use it with a converter.
Marco
(4,281 Views)
Thanks Marco, I appreciate your advice.
Any chance of seeing the code changes you made?
Sean.
(4,266 Views)
Sorry Sean but at the moment I don't have access to that code. 😕
Marco
(4,252 Views)
Did you solve this problem?
(4,169 Views)
