MPC LabVIEW FPGA
How can we implement model predicitve control in Labview FPGA...
I am trying to implement Model predictive control in fpga and the platform that i am using is labview. First stage of the project was over in which i tried to implement MPC in labview and got the required response. But when I tried to implement that one in Labview -fpga module i came across with some errors. Later only I understand that lot of blocks that I used in labview can't be used in Labview-fpga.
Heard that  I should implement mathematically the complete algorithm of model predictive control in labview-FPGA module even for simulation. So will you suggest me how should I approach to this problem.?
(3,060 Views)
Start by reading some previous works perhaps?
http://www.wseas.us/e-library/conferences/2011/Tenerife/ENGCO/ENGCO-17.pdf
Br,
/Roger
(3,051 Views)
