MPPT Based solar tracker PV module using cRio
Hi, I am studying MTech, I am doing project on solar tracking with MPPT controller using NI compact Rio 9014 and i am first using the compact Rio and I need project related help.
(1,486 Views)
Hi Sush,
Which help do you need?
(1,484 Views)
Need information on how to use MPPT in CompactRio project.
(1,478 Views)
What have you already done? How much do you know about MPPT? Have you done some simple cRIO projects and looked and worked through some of the many basic cRIO examples?
MPPT is in theory quite simple. You measure current and voltage and output a control value to adjust the converter electronics to move up and down on the working point depending on the change in power between the previous and current measurement.
What is your converter that you try to control? Or do you want to do the entire converter in cRIO too?
Rolf Kalbermatter  My Blog
(1,474 Views)
