MPU9250 Data Aquisition(Accelerometer, Magnetometer, Gyroscope) using NI cRIO-9076.
I am trying to acquire the data of MPU9250. I have found many LabVIEW codes using the myRIO but there are very less resources regarding cRIO. I have tried a few code but its not working at all. Anyone have any clue or resources how to start it?
(2,396 Views)
Hi AP,
The xCRIO platforms are similar, so most often you can move code from one target to the next.
But: they differ in hardware capabilities and the OS running on the target…
(Your cRIO9076 is "end of life" and rather old.)
So what have you tried so far?
Which errors did you encounter?
Which communication bus do you want to employ?
Do you have the needed hardware for that communication bus?
Any detailed technical information!?
(2,386 Views)
See Moving Examples to a Different FPGA Target to change the RIO target.
https://tmesystems.net/
(2,356 Views)
Thank you for your reply,
Correction to the previous post I have the NI cRIO-9074 not 9076.
Answer to the queries
Response: I tired MPU9250 sensor to connect with cRIO 9074 via digital module 9402.
Response:It is not working
Response:I want to acquire the data through I2C.
Response:I have the 9401,9402 digital module I/O and  cRIO 9074  for communication with the sensor.
Response: I am trying to use a Arduino UNO with the cRIO using the RS232 pin and connect the sensor with the Arduino. Is it possible to apply this method if yes then how to start?
Which method will be adequate to acquire the data from the sensor?
(2,303 Views)
