MQTT publish/subscribe method to measure acceleration using wemos D1 R2
Hi all,
I am trying to measure the acceleration using Tri axial accelerometer ADXL345 connected with WEMOS D1 R2 wifi module and the acquiring data is measured with LabVIEW using MQTT protocol.
I can able to acquire the data, once it is connected to the module, the problem is while trying to communicate with module initially it takes sometime to respond or not responding at all.
I have to try several times to establish the communication between the wifi module and LabVIEW using MQTT.
Can you guys explain, what trouble exactly happening in communicating with LabVIEW?
Even a example program provided by MQTT, doesn't helping me a lot.
Thanks in advance for your favorable reply.
Dinesh
Message 1 of 1
(2,705 Views)
