MQTT subscribe client on Labview
Dear jephin27,
I tried your VI and I can establish a connection. However, I encounter this error:
"Flattened String To Variant in OpenSerializer.lvlib:Serializer.FlattenedString.lvclass:unmarshalling.vi:3430001->OpenSerializer.lvlib:Serializer.lvclass:UnMarshall.vi:4390003->OpenSerializer.lvlib:Serializer.lvclass:UnMarshall (binary).vi:6550002->MQTT Base.lvlib:MQTT_Base.lvclass:Decode Publish Package.vi:2830001->MQTT Client.lvlib:Client.lvclass:Decode Application Message (Type).vi->DropVi_SimpleClientSubscriber.vi.vi".
Can you help me with this?
Thank you!
Message 11 of 13
(1,509 Views)
What type is your received data? Decode Application Message (Type).vi works on LabVIEW data types. Use Decode Application Message (Raw).vi to get a byte array that you can decode according to the received data type.
See here for a detailed explanation: https://github.com/LabVIEW-Open-Source/LV-MQTT-Broker/issues/169#issuecomment-950385388
Message 12 of 13
(1,492 Views)
Thank you for the answer!
I think that the link solved the question.
The data is float but I had to substitute the "Decode Application Message (Type)" with "Decode Application Message (Raw)".
I also added a conversion from byte array to double passing by a string type (maybe it's dumb and there is a better way to do it).
I attach a screen of this part of the VI.
Message 13 of 13
(1,458 Views)
