MRI Simulation - need guidance
Post a new message to that thread to see if you can get a response from Mike since your curent line of inquiry is related to that code and not MRI related (we can't watch every thread anymore ).
Ben
Message 11 of 25
(2,344 Views)
I was able to extract the individual frames - is it possible to convert them to a 3D array without IMAQ?
unc.edu/~msalexan/mriscan.rar
Message Edited by gastro54 on 04-17-2009 11:28 AM
Message 12 of 25
(2,330 Views)
Yes, but I can't help yo now since I don't have anyhting that will handle a .rar file and my boss would fron on it.
Post an image showing where you are having trouble and lets see if we can get you to the next step.
Ben
Message 13 of 25
(2,327 Views)
Simply extract the RAR file into a folder containing the individual JPGs, then read them in a loop as 2D arrays, building a 3D array at the autoindexing output tunnel. 😉
You have all the tools in the plain "graphucs&sound...graphics formats" palette. ("read jpg" followed by "unflatten pixmap").
See how far you get, else I can look at it in a few hours. 😉
Message 14 of 25
(2,322 Views)
OK - here is what I have so far
EDIT: I almost got it I'll post an update when
Message Edited by gastro54 on 04-17-2009 11:59 AM
Message Edited by gastro54 on 04-17-2009 12:03 PM
Message 15 of 25
(2,320 Views)
OK almost there, having some issues padding the file name with the correct number of zeros (0001, 0002, 0003,  ... 0139, 0140).jpg
Message Edited by gastro54 on 04-17-2009 12:13 PM
Message Edited by gastro54 on 04-17-2009 12:14 PM
Message 16 of 25
(2,313 Views)
Good!
Now take a couple of minutes and try plotting just one of those slices to an intesity graph to make sure you can see the image. Depending.... every third byte MAYBE all you need if the image was saved as black/White. Also watch for padding of the pixmap data to an even number of bytes (compare byte count with image size).
If all is Ok you should be able to wire it up to that example I posted for the mouse tendon and then sit back and wait (140 slices will take a while).
Ben
Message 17 of 25
(2,303 Views)
I think I got it!  Heres the final conversion code
EDIT:  Hmmm for some reason the array looks empty?  I used the probe while it was running and it looked like the image was being read correctly..
Message Edited by gastro54 on 04-17-2009 12:32 PM
Message 18 of 25
(2,298 Views)
OK - Fixed it, it needs to be 24bit, not 8bit
Still trying to find ideal intensity scale
Message 19 of 25
(2,286 Views)
Having some weird rendering issues.
While Dragging to change perspective:
After release:
Message 20 of 25
(2,270 Views)
