MS Access Help
Hi all
I have been trying to write to a MS Access data base through activeX. I
realise this is best done through SQL but unfortunately I do not have
this feature. I have managed to have a specific database flash on the
screen but that is as far as I have been able to go. If there is any one
who has done this or nows how to, I would greatly appreciate any help
you could give me.
Thanks In Advance
Greg Tevelen
(2,929 Views)
Hi Greg,
You can try the MS Jet-Engine, which gives you an easier access to the Access
Database. There is also our DAO-Toolkit available, which uses the JEt-Engine.
Demo at www.xon.de (/indexe.html)
Peter
Greg wrote:
>Hi all>>I have been trying to write to a MS Access data base through activeX.
I>realise this is best done through SQL but unfortunately I do not have>this
feature. I have managed to have a specific database flash on the>screen but
that is as far as I have been able to go. If there is any one>who has done
this or nows how to, I would greatly appreciate any help>you could give me.>>Thanks
In Advance>>Greg Tevelen>>
(2,929 Views)
