MS Office Report Express VI and Array Problem
Hello all,
I have a strange issue with the MS Office Report VI that's included with the Report Generation Toolkit. I created an Excel template which I linked using the "Custom template for Excel" preference and applied all the named ranges. However, two of the named ranges that I am inputting are 1D Arrays of doubles. Now the problem:
When I input the arrays to their specific name range (it's only 6 values), instead of inputting just the array values into the cells, it inputs like this:
0    Value
1    Value
2    Value
6    Value
It pushes the "Value" to the column next to the name range because of the 0-6.
It does this with both arrays so it screws up all the formulas. Any one know how to remove the 0-6 and just input the values?
Thanks all
Message 1 of 16
(9,335 Views)
I don't know if this will help, but I'm passing data through a state machine using shift registers. When it's time to add an element to the array, I use the "Build array" function in the state that takes data. All the data is there, but the Index number (0-6) is being included in the report.
Message 2 of 16
(9,323 Views)
It would be better if you can show the code (2009 version please)
Message 3 of 16
(9,310 Views)
Will do on Monday. I was hoping it was a common issue since it's nothing fancy, just a 1d array into the express VI. I'm glad it happened now during the evaluation!
Message 4 of 16
(9,303 Views)
I may be wrong but I think it is because of the way this express vi deal with array. One of its subVI use a Convert to DDT node which add a "channel" value to the rows of an array. If the case, to avoid this you will have to use the Excel specific VIs of the Report Generation Toolkit or if you don't have the toolkit to use ActiveX.
Ben64
Message 5 of 16
(9,296 Views)
Looks like you're right Ben. If you run the code, it pastes 0-5 then 1-6. Is there no other way around this other than using the Excel specific VIs or ActiveX? It's so easy/convenient just using this express VI.
Message 6 of 16
(9,277 Views)
Accepted by topic author buickgn
The Express VI are easy and convenient but at some cost. Since the Express VI can also accept a waveform input you have the accept that it will add a channel name.
With the Report Generation Toolkit (which also have its limitations) it is easy to add only the data as you want:
Ben64
Message 7 of 16
(9,267 Views)
Sounds good, thanks Ben!
Message 8 of 16
(9,265 Views)
Greetings, I wrote a program that generates an array of data and stores a data table, just as a chart, just starting to program, I hope that my program can be useful
Message 9 of 16
(9,156 Views)
I add the program to read a report from excel
Message 10 of 16
(9,153 Views)
