MS Office Report Express VI in a builded application
Where do I have to put the used Exell template defined in the MS Office Report Express VI in case of a builded (.exe) application ?
(2,652 Views)
In your program on the block diagram you have an input for the path of the report template. The report template must then reside at the same path on your target machine as it did on the development machine. Your other option is to let the user navigate to the template to use, but this tends to be a little annoying to the user if it's the same template and the program is used frequently.
(2,651 Views)
Are you sure you are talking about the Express VI, because I see no input for template path ?
(2,642 Views)
Your right. I apologize. My method is for the non-Express vi's. So with the Express vi's you should have a MS Office Report vi that uses a template. If you right click on this and select properties, a configuration window appears in which there is another window where you can navigate to the path of your template. As stated before, your report template must reside at the same location on the target machine.
(2,628 Views)
